by hassy21 » Wed Feb 06, 2008 12:35 pm
I have taken my afc oput and i thought with my afc gone the fuel pin doesnt even work so i just took it out and put a small bolt where the hole is. Do you think that the bolt is not sealing the hole good enough?
