Lift pump lever???
Lift pump lever???
Postby hassy21 » Mon Feb 04, 2008 11:07 pm
On the lift pump it has a lever on the bottom of it and was wondering what that does and where it should be positioned?
hassy21
Postby ford69557ci » Mon Feb 04, 2008 11:30 pm
it is a primer pump for if you run outa fuel or have to change the filter ans my old one locked in the up position
ford69557ci
