What do you think about this HX35?
Postby nooblet » Wed Feb 13, 2008 12:07 am
http://cgi.ebay.com/ebaymotors/ws/eBayI ... T.m240.lVI
He says its a WH1C, but it doesn't have a wastegate on it does it? I asked him what housing it was and he said 12CM. Would this be worth buying do you guys think? If so, how much would you pay?
Thanks,
Chris
nooblet
Postby ford69557ci » Wed Feb 13, 2008 12:21 am
it is the same turbo that came on alot of the ford engines that were powered by a 5.9 seen several of them on f 550 box truck i used to work on i dont think its called an hx 35 though.
ford69557ci
Postby cummins king » Wed Feb 13, 2008 7:15 am
i have a wh1c with a waste gate 16cm for sale on ebay if thats what your looking for
93 4X4 auto
cummins king
Postby fasttalker83 » Wed Feb 13, 2008 9:38 am
I dont think that cross is right the H1C is suppose to be like a HX20 not a 35 the H1D is suppose to be like a 35 if I remember correctly and the tube on that is not like a H1C its bigger,thats looks to be a 2in. compressor outlet to the intake the ones off the first gen was about 1in 1/2 or so I thought
fasttalker83
Postby Philip » Wed Feb 13, 2008 10:11 am
That turbo has a 12cm wastegated housing on it. It doesn't have the exhaust flange mounting plate and it looks like the acuator and linkage are gone also. I wouldn't go over $100 if you want the waste gate to work.
The H1C,HX35,HX40 all have 2" compressor side openings.
Postby nooblet » Wed Feb 13, 2008 11:28 am
cummins king wrote:i have a wh1c with a waste gate 16cm for sale on ebay if thats what your looking for
I really want a smaller exhaust housing, like a 12 or 14. This city driving is killing me :evil:
By the time I catch up with traffic in normal stop/go situations it looks like there is a forest fire chasing me :roll:
I'm looking at getting a smaller housing to help fix some of that. I figured if I'm going to get a smaller housing I might as well try to find a hx35 with a smaller housing already. Its a littler better turbo than my H1C anyway right?
Thats my rational anyway, please let me know if I'm stupid for thinking that :shock:
What are you selling that WH1C for? Or what are you hoping to get for it?
Chris
nooblet
Postby nooblet » Wed Feb 13, 2008 11:29 am
Philip wrote:That turbo has a 12cm wastegated housing on it. It doesn't have the exhaust flange mounting plate and it looks like the acuator and linkage are gone also. I wouldn't go over $100 if you want the waste gate to work.
Thats exactly the info I was hoping to find.
Thanks :rock:
Chris
nooblet
Postby CumminsPride » Wed Feb 13, 2008 12:59 pm
It's only missing the accuator. I'd give 150 in good condition. You can find accuators on here good for 40 or less.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby nooblet » Wed Feb 13, 2008 1:09 pm
CumminsPride wrote:It's only missing the accuator. I'd give 150 in good condition. You can find accuators on here good for 40 or less.
So if i bought it and got an actuator, what would I need to do to put it on my engine? Is it a direct bolt on?
Chris
nooblet
Postby CumminsPride » Wed Feb 13, 2008 1:59 pm
Down pipe needs moved 1 1/4" rearward. This is easiest done by cutting the exhaust before the t case in a stra8 section and getting a band clamp to put it back together after you remove the 1 1/4" out of it.
CumminsPride
