Factory tach q's
Factory tach q's
Postby NYCEGUY01 » Wed Mar 05, 2008 10:50 am
On a factory tach equipped truck where is the tach getting its signal from.
I want to eliminate the computer on this project truck. I allready have the transmission and voltage reg stuff figured out but kinda want to keep the stock tach working.
Anyone ???
96 chevy 3500 4x4 dually. 1st gen Cummins ,nv4500.
NYCEGUY01
Postby PToombs » Wed Mar 05, 2008 2:59 pm
The front balancer. The sensor wire goes down the front of the head, there is a plug there that gets corroded too. ;)
Postby NYCEGUY01 » Wed Mar 05, 2008 9:18 pm
But does the tach get its signal from the sensor directly or from the pcm that gets a signal from the crank sensor ???
I want to eliminate the pcm and need to know if it will still work without it.
NYCEGUY01
Postby cummins king » Wed Mar 05, 2008 9:40 pm
you could always put a mehanical guage in at the turbo line
93 4X4 auto
cummins king
Postby PToombs » Thu Mar 06, 2008 3:00 pm
It comes from the PCM, sorry! I don't know if it will work without the PCM. Mine is wired from the alternator, works good, but you need the right tach.
Postby NYCEGUY01 » Thu Mar 06, 2008 7:05 pm
Damn.
Thats what I thought. I was hoping to leave the factory tach for a stock look in this truck. lol
NYCEGUY01
Postby Philip » Thu Mar 06, 2008 8:40 pm
If you can provide the tach a 5 volt signal it might work. The signal the tach recieves from the PCM is a 5 volt square wave signal. I think the PCM just reads the signal then sends it to the tach with no conversion of any type.
