by fourwheelininajeep » Fri Mar 14, 2008 9:28 am
I think I may have figured it out, the diaphram and hose all seem to be in good shape, I noticed last time that the pattern where the little needle was gliding on the pin wasnt even touching down towards the bottom where I grinded it, I thought that I grinded the fuel pin to far and that was all the travel that needle had, but I think that the needle isnt coming all the way out, if it is then I didnt even need to grind the pin in the first place, so something must be wrong according to the smokey fuel pin on this thread that I followed you should cut away a 1/16 of an inch before it wont work anymore, my boost and egts are kind of finnicky anyway sometimes I pull 30 pounds other times I can only pull 24 or 25, same temperature same hill same amout of humidity, I think that pin is just sticking bad, it seems to run better on a hot day (70 or 80) than when its cooler 50-60 which is ass backwards. I will try to lubricate that pin with some wd40 or somthing and see if I can get it freed up
1990 dodge w350 cab and chassis frame single rear wheel 99000 miles with chrome stacks between cab and bed paid 1300 for it after a years worth of work i got to drive it
