Seal BLOWOUT!
Seal BLOWOUT!
Postby 75Dodge » Wed Mar 12, 2008 10:54 pm
And it's not a great sale! THe front seal blew out on my pump. And it dumped a crap load of fuel into my oil. I was driving it on the freeway mostly around 60-65. with the occasional push into 70-75mph. I get into town and I get a low oil pressure light and my gauge drops to nothing...
Open the hood at home and fuel is pouring out the front of my front gear case...
I removed the pump and the front seal on the pump is just popped free. And it isn't torn up. I just rebuilt the pump about 600 miles ago and now this...
What would cause this to happen? What do I about the fuel in the engine oil? I know to drain it and change the filter, but should I use some sort of detergent in the motor?
Any help you guys can provide will be great. THANKS!
1989 D-250 LE Automatic 150hp at 55mph! 3200K Spring, tweaked pump, H1C/H1E hybrid.
75Dodge
Postby KTA » Thu Mar 13, 2008 5:10 am
How much fuel pressure are you running, are you sure you used the correct seal? You could use some red loctite on it to help hold it in. I have had good success with that in place of a seal retainer.
Postby PToombs » Thu Mar 13, 2008 4:09 pm
Just change the oil and filter, should be ok. What little bit is in the galleys won't hurt anything. Might want to pull the shut off solenoid wire, and crank it until the pressure comes up. ;-)
Postby cummins king » Thu Mar 13, 2008 7:42 pm
do non of you guys think that a high pressure seal will work
93 4X4 auto
cummins king
Postby 75Dodge » Thu Mar 13, 2008 11:10 pm
Hey KTA, I am running stock pressure. Other than the 3200K spring, I don't have any other mods. The full load screw isn't even turned up... That is why I think the seal wasn't seated properly.
Thanks for the info!
75Dodge
Postby cummins king » Fri Mar 14, 2008 6:28 am
if it blew out with stock fuel pressure then you have a setting issue, mine blew out at 30psi double stock pressure
93 4X4 auto
cummins king
Postby 75Dodge » Sun Mar 16, 2008 9:21 pm
So the question now becomes how do I install it properly?
75Dodge
