How to make a Cummins efficient?
Postby cummins king » Mon Mar 17, 2008 7:10 pm
Well, do to the rise in fuel prices, How do we make our trucks effiecnt?
In threory these things should be able to run 30+mpg.
Some super efficient injectors would be good
good quick spooling turbo,
big exaust
good cam
special pump
If you have any ideas lay them out
Joel
93 4X4 auto
cummins king
Postby ford69557ci » Mon Mar 17, 2008 8:06 pm
if i drive normal and keep it70 or uner on the highway i get 22 24 mpg thats pretty good for a modded truck with mt's
ford69557ci
Postby 2muchtq » Mon Mar 17, 2008 8:50 pm
I get an 'extra' 2 mpg by driving 60-65 vs 72-75
My truck hit 20 for the first time since I have owned her.
Bump timing a touch. Good injectors. Free flowing intake/exhaust.
2muchtq
Postby OLDEARL93 » Mon Mar 17, 2008 8:53 pm
I CHANGED MY TURBO FROM AN HIC TO HX35 AND LOWERED THE RPM'S A LITTLE BIT AND WITH MY CAMPER WEIGHT OT ONE TON PLUS AROUND TOWN I AM GETTING 16 + AND ON FREEWAY DRIVING UNDER 70 AT 1700 RPM'S I GET 20+ I THINK THE TRICK IS TO LOWER YOURE RPM'S AND TO SPOOL FASTER ,IT HAS WORKED FOR ME ,HAVE TO RESEARCH IF A LARGER EXAUST WOULD HELP AND WHETHER IT WOULD JUSTIFY THE COST.
93 4X4 EXTRA CAB 5 SP. GERT.EGT,BOOST ,RPM GAUGE,TIMMING AD,PUMP TWEEKED,NEW HX35,REST STOCK
OLDEARL93
Postby ford69557ci » Mon Mar 17, 2008 9:47 pm
I think a good set of matched twins, good edm'd sticks, a ported head(intake and ex sides both) some good free flowing ic tubes with a dual inlet on the head, a good cac, free flowing ex and intake, and a 5spd or a lock up auto should be the formula to good fuel mileage and power. Now take that combo and drive hard and have fun with 14mpg or less but drive it normal and then you will see 20 plus. oh i forgot a cam in that mix too. As much as I dont like Banks stuff I have some friends that have gotten some very good economy improvements with the complete air flow packages they offer so it just proves that the airflow to burn the fuel will make it go farther. I have found that my truck tends to do a little better running red dye?? I am not sure if its the place I buy it vs the other fuel in towns quality but i have heard red dye is a different formula.
ford69557ci
Postby cummins king » Tue Mar 18, 2008 5:37 am
but with that formula who would keep there foot out of it
93 4X4 auto
cummins king
Postby ford69557ci » Tue Mar 18, 2008 1:15 pm
i usually dont drive hard unless its a race or pull
ford69557ci
Postby oldestof11 » Tue Mar 18, 2008 1:32 pm
Dont forget a big rear end that came with the 727 auto. 3.07 and a 5spd was getting rbtrettctd 21 mpg on the free way and keeping up with some Dmax's. Take that you over electricalized wanna-be diesel V8's :lol:
Postby dpuckett » Tue Mar 18, 2008 4:04 pm
rbrett got 21 before the auto to manual conversion. He has seen 27-28mpg hwy since the direct connection and overdrive.
DP
Postby GO OVRIT » Tue Mar 18, 2008 6:40 pm
I'm really hoping that the ats converter is going to make my auto get close to the 21 that my getrag truck got.
GO OVRIT
Postby mhuppertz » Fri Mar 28, 2008 2:50 pm
Put a 2x4 under the foot feed!
I'm getting high 19's around town with POD's by taking it easy and coasting where I can.
mhuppertz
