Piston type lift pump question LP vs HP
Postby BobS » Wed Jan 17, 2007 9:32 am
I have gathered the following information from over on DTR so correct me where I am wrong:
The maximum pressure to a Bosch VE pump should not exceed 20 psi for any extended duration or the VE pump will encounter seal related leaks.
The lower pressure piston lift pumps are regulated to 15 psi maximum output.
The only physical difference between the lower pressure and second generation higher pressure lift pumps is the ones for the second generation are set at 30 psi by incorporating a longer length pressure relief spring.
So the question is why can't we take a high pressure lift pump that is sold through most auto parts stores and trim the pressure relief spring to get the lower pressure that we can use with the VE pump?
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby dpuckett » Wed Jan 17, 2007 9:46 am
Because it would probably cost about the same in the long run, plus you KNOW the LP VE pump is set to 15psi or so. No experimentation required.
Daniel
Postby sdstriper » Wed Jan 17, 2007 11:48 am
The part number for the Low Flow Lift Pump is over there too, in the Tech section, along with the rest of the parts that it would take to convert. There is a spacer, couple gaskets, fuel line and the pump, No spring trim necessary.
sdstriper
Postby Bob Beauchaine » Wed Jan 17, 2007 3:10 pm
If you already have a HP pump you could always get a LP rebuild kit. As I understand it they are the same except for the spring. The piston pump is made by Carter and Cummins might be able to supply a rebuild kit otherwise I've got to agree with everyone elce.
Bob
1993 CTD 4X2 Horton fan,Green HP AF,Old Smoky BHAF ,PDRHX35-14cmW/G, ATS exh-P&P,15%+ VE/Old Smoky power pin, DD3+ injetors, BD Exh brake, 4" Rip Rook Exh, NV4500HD, SB Con-O clutch, guages, 3200 GSK, Snow W/M Stage 3 - 381/888 on #2 - 417/827 on W/M
Bob Beauchaine
Postby Greenleaf » Thu Jan 18, 2007 10:07 am
When the fuel pressure reaches the injection pump, it is fed into the vane supply pressure pump. This pump increases the internall pressure to a varying degree. Much above and well over 15/20 psi.
It's been stated that 30 psi supply will have an effect on the timing of the injection pump. Will tend to advance a bit. I'm not sure if it's due to additional pressure above what it normally would be at, or not......
On another note, the shaft seal is a lip seal. A lip seal is good to say, 14 psi. Yet the lip seal on the shaft of our pump is subjected to internal pump pressure. :shock: :? :!: I blow lip seals all the time on my farm tractor transfer pump. :x They don't hold much in the way of pressure as they are not intended for that application.
Greenleaf
tech specialist/mod
Postby gman07 » Thu Jan 18, 2007 2:39 pm
As for that seal, I heard KTA is running a seal retainer of sorts to run higher inlet pressures...
KTA, want to enlighten us some, or is it one of those super-secret black topics? :lol:
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby Greenleaf » Fri Jan 19, 2007 5:30 am
It's still a lip seal of sorts I imagine. I have heard tell of a retainer but that won't assist the "lip" portion of said seal. A retainer would, IMHO, simply keep the seal body from blowing out of the pump housing bore.
I simply run with 16 psi supply and don't fret the small stuff. No problems thus far.
Greenleaf
tech specialist/mod
