...In fuel lines, that is? Reason I ask is, I'm pondering finally getting around to upgrading the stocker fuel lines. I've got good flow with the mods I've already done to the the filter and pickup, steady around 15psi, even at WOT. Just anticipating some new injectors someday. Maybe I'll need a bigger main feed line. I'll do a 3/8" line from the tank to the filter. But I was looking at the return line where it leaves the IP, and looks like a REALLy small line. Like maybe 1/4" at most. Yet occasionally I see talk about upgrading the size on that return line. What's the reasoning? Does the VE actually return more when it is fueling more? I'd a thought that was just pressure regulated somehow. Does it need more flow out the return at some point?
Any hints or tips appreciated....
