Just got a ISSPro 60psi boost gauge installed, and I was disappointed to find that my boost pressure WOT is only 15psi.
Is this normal? Should the engine alway run under about 5-7 psi boost? Is there a way to adjust the boost?
PToombs wrote:Maaaaann, all you guys need more fuel!I can hit 42 pretty easy.
opofus, fuel is boost. More fuel, more boost. It won't have much boost running down the road steady. If you come to a hill, or step on it, it will come up. At 70 mph, I run about 3-5 psi. If I have the trailer on, the weight difference is noticable. 10-15 psi.
If you want more boost, turn the fuel screw in.
