SChandler wrote:For those of you who are running a fuel pressure gauge, where do you get the reading from? I was thinking about replacing the bleeder screw with a banjo bolt/fuel pressure gauge tap that I got from Geno's Garage (assuming it fits, they list it for 24 valve motors). Would that cause problems or is there another place to pick up the reading?
Ace wrote:If you're really worried about it you can use an isolator to keep fuel out of the cab, but they're expensive. I put a needle valve and snubber on the FP line. The valve is just cracked open, so even if the line was cut in the cab it would only drip. Maybe a fast drip, but nothing to worry about too much if I pull over, pop the hood, get out and close the valve.
I prefer mechanical gauges. More reliable. JMHO.
