dpuckett wrote:The early KSB is activated with a lack of power, so leaving it unhooked will advance it; running power to it will retard it. The latter pumps are the opposite.
Do what I did- run a wire from the shutdown solenoid to a switch in the cab, then back to the KSB solenoid.
Or just power it up all the time. Contrary to popular belief, it IS possible to get too much advance.
Daniel
bgilbert wrote: I guess I'll just jumper a wire from the the run solenoid down to the ksb for now.
