Finaly, I got the new Seals in
Postby cummins king » Mon May 12, 2008 8:05 pm
Okay the seals are finaly in, there only 3 weeks late but.... what ever
So i did some quick testing and they look great they held fine at 55psi
I order 20 this time and i have 7 spoken for so theres 13 left
there $20.00 each shipping included
when i first tested the first batch at 40psi it pushed out and self destructed
when i talked to the seal maker he said that you must run a retainer
so i put the first batch seal in my pump is for the little bit i was able to run it at 55psi it held great
now these new seals are thicker and HD
i still recomend running a c clip, it takes a machine shop all of 30 mins to get it done and you will never worry again
heres some pics
c clip
i wasnt able to get the pic of the new seal in the pump, maby tomorow
this pic is just an old one
PM me if your intrested
Thanks
Joel
93 4X4 auto
cummins king
hey man
Postby boostedve » Tue May 13, 2008 5:23 am
ill take one of them seals.
and can you tell me what spring may be broke in my pump..
FOR SALE 1991 dodge d350 hx40 2nd gen intercooler, few pump mods, 366 spring, no afc, timing bump,pistion lift pump, 5" down pipe, bhaf, old smokey fuel pin, boost, pyro, tach gauges 14.10 @96mph 310hp, pm for pics and info..
boostedve
Postby sdstriper » Tue May 13, 2008 4:04 pm
I'll tell you which one it is. It's the broken one... ;)
sdstriper
