run away on fuel screw?
Postby krazykarl454 » Sun May 18, 2008 7:57 pm
so how many turns can u go in on your power screw b4 it starts to run away? i turned it in about 2 turns and it was running strong, and wanted more fuel, but it felt like it was tryin to run away. as i was driving i would let of the pedal to shift n it would hold that RPM for about 5 seconds b4 it would start to drop, but it never the RPM never jumped up, it was likethe throttle was stickin, but it wasn't, i checked out all the linkage and springs and everythnig snaps back ok. ALSO.... if i turned the screw back down like a 1/4 turn it wouldn't do it, and b4 i touched the screw it didn't have a problem. also it felt like it was bottoming out when i turned it in the 2 turns? i herd of people doin like 4 turns? what gives. my MODS are hx40, POD's, 3Gsk, n fliped the fuel pin to the deepest settin, and removed the plastic spacer under the diaphram. THANKS for the help
86' GMC 3500 (cummins swap: hx40, POD's, I/C 5" exhaust) , custom 4-link front end, about 9-inchs of lift, dana 60 4.56s welded/ 14-bolt, 4.56s detroit. grooved 38.5 x16 TSLs, custom frt/Rr bumpers, 16.5 super sinlge welds
krazykarl454
Postby boostedve » Sun May 18, 2008 8:42 pm
sounds like you at the point of runaway.. some people can get 4 some can get 8. what i do is i turn the fuel screw 1/2 turn at a time and hit the throttle. if the rpm come back down right away then go another 1/2 turn untill it hangs and slowly come back down. at that point i back it out a 1/4.
if it were me i would back it out a 1/4 being that yours is a stick. this way its not hangin up ther when you go threw the gears..
FOR SALE 1991 dodge d350 hx40 2nd gen intercooler, few pump mods, 366 spring, no afc, timing bump,pistion lift pump, 5" down pipe, bhaf, old smokey fuel pin, boost, pyro, tach gauges 14.10 @96mph 310hp, pm for pics and info..
boostedve
Postby SChandler » Sun May 18, 2008 8:59 pm
Hanging rpm's in between shifts is a sign of being on the edge of runaway. In my 92 I only got 3 turns on the fuel screw before I reached that point. On my 90 2 turns produced some interesting behaviors. When I was driving in stop and go traffic in second gear, once I got above 20 it wanted to accelerate up to redline without any additional throttle input. I could let out of the throttle and it would immediately drop speed and rpms, it never hung rpms between shifts, but it just wanted to accelerate by itself in a low load/high rpm setting. Every injection pump is different.
SChandler
Postby Begle1 » Sun May 18, 2008 9:29 pm
It's a fun trait of the VE pump...
How when you're up over 2300 or so RPM, and you take the foot off the pedal, it kind of wavers back and forth by itself until it slowly comes back down through assistance with the service brakes.
I wouldn't trade that for anything. 8)
Postby krazykarl454 » Mon May 19, 2008 5:11 am
well i guess its ok, as long as this is normal, i'll back that screw out a 1/4 turn b4 i go to work. yea im pissed b/c it definetly wants more fuel, the EGT's were just starting to pull to 1400 too. so what should be my next step to get her somemore fuel? grind the fuel pin old smokey style? well thanks alot guys.
krazykarl454
Postby 89silverbullet » Mon May 19, 2008 7:08 am
how does it idle?
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Postby SChandler » Mon May 19, 2008 7:36 am
I'd grind the fuel pin. I have a DDP fuel pin (like the Old Smokey pin) and it helped top end fueling. The thing with grinding the pin is to not take any (or only a small amount) off of the bottom (wide end) of the ramp and to take more off as you move up the ramp. This will help keep low end smoke manageable while giving you more top end fuel.
SChandler
Postby krazykarl454 » Mon May 19, 2008 8:00 pm
well it idles great, starts no problem. the idle did rise but its smooth. and thanks for the fuel pin tips, i'll hav eto get on that one of these nites
krazykarl454
Postby CumminsPride » Tue May 20, 2008 10:49 am
With that 40 on there I'd remove the AFC.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Richie O » Tue May 20, 2008 8:13 pm
I have noticed that my govenor does not act like a Diesel gov any more. I can push the pedal 1/8 way down and it will rev all the way up in nuetral. It almost acts like a non gov gas engine now. Does not bother when driving.
Postby racerdude_9 » Tue May 20, 2008 8:41 pm
did you adjust your idle back to normal after u adjusted your fuel pin?
1991 CTD
racerdude_9
Postby krazykarl454 » Tue May 20, 2008 8:46 pm
as remove do you mean ,cut off the AFC foot? or can i try it out by just pullin the fuel pin out? so richie tihs is after u put the spring in or messed with the screw?
krazykarl454
