Turbo Change
Turbo Change
Postby lazyjoe » Mon May 19, 2008 11:26 am
I have a chance to buy a turbo off of a 98 12V. Will this fit on my 93, and what changes can I expect. I'v been wanting to upgrade my turbo and exhaust. Would this be a good move, or would I be better off with an hx35, or something like that. The truck has 255,000 miles on it, so I don't want to push it too hard. I mainly pull stock trailers with it, and soon it will have a flat bed, and hay spear. Any suggestions would be great.
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
Re: Turbo Change
Postby flashgordon » Mon May 19, 2008 11:32 am
lazyjoe wrote:I have a chance to buy a turbo off of a 98 12V. Will this fit on my 93, and what changes can I expect. I'v been wanting to upgrade my turbo and exhaust. Would this be a good move, or would I be better off with an hx35, or something like that. The truck has 255,000 miles on it, so I don't want to push it too hard. I mainly pull stock trailers with it, and soon it will have a flat bed, and hay spear. Any suggestions would be great.
The 98 12V is, a HX35 and will bolt right up. the only question is in the exh area, as the waste gated housing will push the exh back about a inch
The 99 and newer 24V would take a little bit more work.
Flash
flashgordon
Postby PToombs » Mon May 19, 2008 3:36 pm
I had an HX 35 from an 01 on my truck briefly. I kept my 16cm exhaust housing and put the rest of the 35 on that. No moving the pipe or anything. I didn't notice a big difference. I went and bought a stage IV kit for my H1C, it only had 15k on it anyways.
Postby mprmn08 » Mon May 19, 2008 4:14 pm
whats the stage IV consist of? Also what does it do and were did you get it?
mprmn08
Postby PToombs » Tue May 20, 2008 5:47 pm
60mm 6 blade wheel, compressor housing, and a backing plate, from HTT. It's hard to get parts from them now, GDS has the same thing, minus the plate, (you machine yours) for $100 less. The 6 blade wheel is taller that the 60 mm 8 blade.
A stage III has an 8 blade 60mm wheel, and the housing. Use the stock backing plate.
What it does is crams a lot more air in there! ;) :lol:
Postby mprmn08 » Tue May 20, 2008 6:54 pm
do you know the web site for gds? i cant seem to find it. I found htt but not gds. Thanks alot for the info on that.
mprmn08
Postby SChandler » Tue May 20, 2008 10:25 pm
GDS can be found here: http://www.gdsdieselparts.com/ or here (this is their new website, minus Dodge apps for now, according to their old website): http://www.gillettdiesel.com/.
SChandler
