Quick Question
Quick Question
Postby whereswaldo250 » Thu May 22, 2008 7:51 pm
Will a turbo mounted exhaust brake have enough room to fit on a 14cm2 housing? I mean will it hit the fire wall?
If anybody has tried this let me know
Thanks :D
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby dpuckett » Wed May 28, 2008 7:41 pm
I would think it'd work. There is plenty of room with the non gated housing, so though it may be a little snug in there with the gate, it should fit alright.
Daniel
Postby JHPC » Wed May 28, 2008 10:38 pm
I had a 14cm2 wastegated housing on my 91.5 w/Pacbreak and it fit just fine . I changed it out for a 16cm2 non wastegated and gained 5#s of boost.(it is also an auto trans)
JHPC
1991.5 W250 LE A518 w/8000# Warn Winch and Bumper, Pacbreak, Icebox, Banks exhaust, 366 spring, turned fuel pin, full power screw 2 turns, Isspro R5503 tach., Banks trans. temp. gauge, Autometer pyro. gauge, US Gear boost gauge, 16cm exhaust housing and potentiomter.
JHPC
Postby CumminsPride » Thu May 29, 2008 4:34 am
JHPC, What's your tranny think of that pacbrake when you're going down long grades? Do the temps rise quickly? I never heard much good repor on any exhaust brake with a non lock up trans.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
