Bad news or coincidence? (injector pump blues)
Postby dodgetkboy78 » Wed May 28, 2008 12:20 pm
So, I was driving, down the road, and my truck started to act as if it was running out of fuel................it did it about 30 seconds, just long enough for me to pull over, and let it idle (re-lube my poor injection pump) and say *(&^^%#%^$&*(@$^#^...............
I tried it again, and it runs fine, like bat out of hell, 35 pounds of boost, black smoke, the whole nine yards.
Ten minutes later, when I went to shut it off, well? It wont shut off without me pulling the mechanical kill. :?
Strange coincidence? Or id my pump on the fritz or something? :?
Someone did tell me turning in the screw as far as it will go will kill my pump.
dodgetkboy78
Postby SNOOT » Wed May 28, 2008 2:05 pm
Sounds like the fuel shut off solenoid to me. It should be the part that the two wires goto on the back of the pump.
1993 W350
SNOOT
Postby CumminsPride » Wed May 28, 2008 2:24 pm
Pull your fuel selinoid and gut it. The trash from the end of it just went through your injection system! That's cool. Throw a pull cable on there and join the club.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby dodgetkboy78 » Wed May 28, 2008 6:26 pm
Oh special.
It has one on the front of the pump, with a fuel line running through it, or some kind of line.........and the one on the back.
The kill it on top of the rotor, right?
dodgetkboy78
Postby dodgetkboy78 » Fri May 30, 2008 1:10 am
Well, it seems to have self destructed in there.................pieces of metal everywhere..........
O well :(
dodgetkboy78
Postby CumminsPride » Fri May 30, 2008 4:16 am
Yep! That's what happens. I pulled mine out when I removed the afc just as a precaution.
CumminsPride
Postby dodgetkboy78 » Sat May 31, 2008 1:48 am
So, if I pull it now, is there any way to get that crap out of there without taking the damn thing apart? The 11MPG my gas trucks getting, and my buell acting like an ass is killing my pocketbook!
dodgetkboy78
Postby CumminsPride » Sat May 31, 2008 4:33 am
Sorry, no way to truly clean it. Pull it and start the thing and see if it runs? You could pull the lines and DV's and clean them if you like but put the same DV's back exactly like they were.
CumminsPride
Postby cummins king » Sat May 31, 2008 5:50 am
get a budy to start the truck while you hold the mechanical shot off back
leave the electric sylinoid out, maby wear googles, and you might need to blead you injection lines after
that should flush some crap out for you
93 4X4 auto
cummins king
Postby BEARKILLER » Sat Jun 07, 2008 11:01 pm
cummins king wrote:get a budy to start the truck while you hold the mechanical shot off back
That is a good one to file away in the old brain for just such occassions.
#4 = 1991 D-350 LE Getrag
BEARKILLER
