Strange No Start?
Strange No Start?
Postby Begle1 » Sun Jun 01, 2008 5:42 pm
I turn the key, and I hear a single click in the engine compartment, but it doesn't crank.
I jumper the plug off the battery, and it cranks and starts fine.
What am I missing? How do I hear a click in the engine compartment when I turn the key, but no start?
Postby mprmn08 » Sun Jun 01, 2008 5:43 pm
possibly nuetral safety switch bad?
mprmn08
Postby Begle1 » Sun Jun 01, 2008 6:05 pm
Would that still fire a solenoid?
I replaced that a year ago...
Postby Richie O » Sun Jun 01, 2008 6:13 pm
I had one of mine do that a year ago. Tried it later and it started. Has started ever since :roll: It clicked something under the hood but no start. I did not try anything under the hood to get it running, just took another truck. Guess it fixed it self :D
Postby Begle1 » Sun Jun 01, 2008 6:45 pm
It's intermittent. Doesn't seem to do it unless I leave it for more than a day.
Postby mprmn08 » Sun Jun 01, 2008 7:29 pm
next time it does it try and jump the starter and if it fires fine it should just be the neutral switch.
mprmn08
Postby lazyjoe » Mon Jun 02, 2008 9:01 am
Mine did that a couple of months ago. I tapped on the starter and it started. It would only do it when it was hot, so I didn't worry about it to much. until I forgot, and shut it off at the bruams drive-up window. I changed it the next day.
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
Postby seeker1056 » Mon Jun 02, 2008 9:54 am
your solenoid is on the way out, if it isnt a deadspot on the armature - either way it is new starter time
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Begle1 » Mon Jun 02, 2008 10:21 am
So the starter solenoid is what I hear clicking.
The starter solenoid is making a click, but is not functioning to engage the starter.
The starter solenoid is malfunctioning either because it is worn out, or because it is seeing insufficient current or voltage from the ignition switch.
Jumping the starter solenoid will work temporarily, but if the solenoid is worn out, that process too will cease to function eventually.
Correct?
Postby Falcon » Mon Jun 02, 2008 12:23 pm
Battery may be DEADnot holding enough to fire it off just enough to click the solenoid
Greg
Graham, Washington
"FIRST REAL TRUCK ENGINE...
LAST REAL TRUCK!!!
93 ex cab 4x4, Hybred 35/40,4" exaust all the way,pump turned alittle,DDP Stage III's, 366 spring,DDP fuel pin,AFE first gen air intake,pyro and boost gauges
Falcon
Postby SChandler » Mon Jun 02, 2008 1:55 pm
Mine would click but not start when the battery died in my 90. I would take it someplace reputable and have them check the battery. Also check the cables to the starter for corrosion. I had one that the insulation split open on the bottom and when I found it, it wasn't pretty.
SChandler
Postby Begle1 » Mon Jun 02, 2008 9:17 pm
If it was the battery or contacts, why would it not skip a beat when I jump the plug at the battery?
Postby BEARKILLER » Sat Jun 07, 2008 10:57 pm
I don't think it's the battery, and it ain't the starter; because, jumping across the starter-wire plug is obviously starting the engine.
The starter relay on the left fender could be bad; or, as already suggested, the neutral switch, OR IT'S PLUG at the transmission could be bad.
Find the wires that plug into the neutral-switch, un-plug them, clean all the contacts, dielectric grease, and plug back in, then see what happens.
You can test the starter relay with a test-light at that plug where you are jumping it.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Solenoid Repair
Postby Ace » Sun Jun 08, 2008 5:40 am
You can get the soleniod repair kit off eBag for around $25.
Ace
Postby PToombs » Sun Jun 08, 2008 5:17 pm
Alternate method. Use a voltmeter, start at the starter activator wire and check voltage. If it's low, check back up the wire until you find the bad connection. If you have 12 volts, problem is most likely inside the starter.
