Crankshafts
Crankshafts
Postby fasttalker83 » Thu Jun 19, 2008 2:06 pm
Is it possible to stick the crankshaft out of a 12valve into a 24valve motor I have a bus motor sitting here that has a good crank in it and a guy broke the crank in his 24valve I dont think there would be alot of difference but hey what do I know
fasttalker83
Postby KTA » Fri Jun 20, 2008 7:55 am
If it is a stock electronic 24V it won't work. The 24V crank has a tone ring on it for a crank position sensor. The 12V crank does not and therefore the electronics wouldn't work.
