ANother water-to-air aftercooler
Postby dpuckett » Mon Jun 23, 2008 8:21 am
Found this on ebay- http://cgi.ebay.com/ebaymotors/Parts-Ac ... 263103903&. For those looking for a water-to-air aftercooler.
Daniel
Postby gear jammer 91" » Mon Jun 23, 2008 6:27 pm
If it helps you pick a bid price I found these new from a boat repair shop on the coast for around $400. I don't think that came with fuel lines though. I was thinking about goin that route myself but I ended up with an old air to air.
01 LB7
gear jammer 91"
Postby PToombs » Tue Jun 24, 2008 5:52 pm
$36 and 8 minutes left! Hurry and get your bid in! :shock:
Postby bgilbert » Tue Jun 24, 2008 7:03 pm
It's ebay, he's got a reserve, shipping is high dollar and I lost 25hp using one of these. Could've been other issues though...
Bill Gilbert
bgilbert
Postby sdstriper » Tue Jun 24, 2008 7:06 pm
$56 at auction end and didn't meet the reserve, he stated he has multiple units and gave phone number. Also, he has had many, many turbos etc on there that they didn't know much about, truck salvage IIRC.
sdstriper
Postby c12h26 » Wed Jun 25, 2008 6:29 am
I put one of these water to air intercoolers on my truck http://cgi.ebay.com/ebaymotors/NEW-3-Air-to-Water-Liquid-Intercooler-A2W-w-Fittings_W0QQitemZ220249687724QQihZ012QQcategoryZ33742QQssPageNameZWDVWQQrdZ1QQcmdZViewItem.this one is only $85
here is a pic of water to air intercooler on my old 91
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Jacket Water After Coolers WARNING
Postby BobS » Wed Jun 25, 2008 10:04 am
WARNING - JWAC's do go bad! If it was off an engine that was run without an air cleaner they accumulate debris and either plug up or start to rust shut. Salt water air can also take its toll. Get a picture of the bottom opening before you buy one. I have a bad one here from a 4BT engine that someone drilled holes through the fins so the air could get through.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
