Top Speed????
Top Speed????
Postby Rug_Trucker » Tue Jul 01, 2008 9:27 am
On the mat yesterday on flat ground 79-80mph. Nothing more! :shock:
That sound right for a '93 D350? I don't know the rear gear.
72 slant Duster M-1 2bbl Hookers
79 Maxivan Offy Comp RV cam0
74 Dart 225 4 DR
93 D350 CTD auto
various KW's and Freighliners with 10spd auto shifts
Rug_Trucker
Postby dpuckett » Tue Jul 01, 2008 9:55 am
If it's stock RPM with 4.10 gears, that's about right. If you have 3.54s, check throttle linkage slack, and make sure you're getting full throttle travel.
There SHOULD (operative word) be a tag on the rear diff between two vertically aligned bolts with the BOM# (6 digit) and ratio. If you have a nicer truck, it may be on a tag under the left front edge of the hood.
Daniel
Postby SNOOT » Tue Jul 01, 2008 1:26 pm
I can hit 100MPH and still have room on the floor.
Auto with 3.54...
1993 W350
SNOOT
Postby cummins king » Tue Jul 01, 2008 4:15 pm
93 auto -4:10s -160 kms, with out OD
93 4X4 auto
cummins king
Postby dpuckett » Tue Jul 01, 2008 8:32 pm
SNOOT- you have a rare pickup (or a tight tranny and 366 spring)- Mom's would do almost 100mph 10 years ago; wont hardly do 90 now, even with a new tranny.
DP
Postby gear jammer 91" » Tue Jul 01, 2008 8:55 pm
my work truck is a 93 extra cab 4x4 duallie. It's got a getrag and 4:10's I've turned the pump up and it will only do 71mph :x I haven't had a chance to check the throttle travel though.
My 91 with 3:54's, a getrag, turned up pump would only do 90mph before my 366 spring. Now it will break 100mph. :lol:
01 LB7
gear jammer 91"
Postby Rug_Trucker » Tue Jul 01, 2008 9:53 pm
I checked for a tag when I was buying the truck. None there. The rear had been rebuilt. The ABS light is always on :( Might not hooked that up right?
When I get time I will jack up the rear and check it. I do know it is a sure grip. I dug some mighty bi holes in the driveway power breaking it :lol:
I wouldn't doubt that throttle linkage is sloppy. I have the next two days off and I a working on the 4 speed project, and BBD rebuild for the Duster.
74 Dart 225 4 DR
93 D350 CTD auto
Rug_Trucker
Postby dodgetkboy78 » Wed Jul 02, 2008 11:51 pm
I think my 3.54 dually with getrag does 92, uphill, downhill, or flat.
dodgetkboy78
Postby Philip » Thu Jul 03, 2008 5:52 pm
My speedo doesn't go high enough. I can peg it at will.
A couple of weeks ago when the truck got dynoed the operator spun it up to 135 MPH. Then he decided he was going to dyno it in 3rd instead of OD. :lol:
It defueled at 92 MPH roller speed in 3rd. Thats with a stock governor spring also.
Postby Rug_Trucker » Fri Jul 04, 2008 4:00 am
Defueled?
74 Dart 225 4 DR
93 D350 CTD auto
Rug_Trucker
Postby Richie O » Fri Jul 04, 2008 8:30 am
Both of my 89's with 727 and 3.08's maxed out at 76 to 80 mph. before high idle screw was backed out. That is plenty fast for these pigs. Stoping as we all know is a chore.
Postby PToombs » Fri Jul 04, 2008 6:05 pm
Rug_Trucker wrote:Defueled?
RT, that's when the governor stops fueling at top end. ;)
Postby Rug_Trucker » Fri Jul 04, 2008 7:08 pm
Well now we are learning!
74 Dart 225 4 DR
93 D350 CTD auto
Rug_Trucker
Postby SNOOT » Sat Jul 05, 2008 2:54 pm
dpuckett wrote:SNOOT- you have a rare pickup (or a tight tranny and 366 spring)- Mom's would do almost 100mph 10 years ago; wont hardly do 90 now, even with a new tranny.
DP
Its got all of that I need to post some video for you .... I can do 100mph all day long but the fuel to do it would cost a little..
1993 W350
SNOOT
Postby Rug_Trucker » Sat Jul 05, 2008 10:45 pm
I bought a '56 VW beetle from a guy. It had the owners manual in it.
Break in speed? 72mph
Top cruising speed? 72mph
Top speed? 72mph!!
74 Dart 225 4 DR
93 D350 CTD auto
Rug_Trucker
