3 ply silicone hose?
Postby PToombs » Fri Jul 25, 2008 5:55 pm
Is 3 ply enough? I was just on the Bay and found a reducer hose and clamps for $16 and shipping. It says 240 psi burst and 80 psi working pressure. Good enough? It's not a hump hose and it looks real short, only 3 inches long.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 24367&rd=1
Postby Richie O » Fri Jul 25, 2008 6:27 pm
I bought mine from these guys.
http://www.siliconeintakes.com/index.ph ... dba41897b4
AKA as Frozen boost. com. Same company.
These were only 3 inces long also. Kinda are cheesy but get the job done. The worst part was shipping was pricey....
Postby GO OVRIT » Fri Jul 25, 2008 7:33 pm
Mine are all 3 ply silicone hump hoses. I got a 3 to 2.5 hump reducer off ebay one time, but I don't see any on there now.
GO OVRIT
Postby Philip » Fri Jul 25, 2008 9:02 pm
Pete I got a 2.5" to 3" if you need one. It is blue. You will need clamps. Call me tomorrow night if you want it.
Postby PToombs » Sat Jul 26, 2008 5:20 am
Richie, only 200 psi burst and 50 working pressure. Not much margin there. :shock:
Philip, thanks. I'll call you.
Postby Richie O » Sat Jul 26, 2008 9:47 am
Ya... I don't think I will be at 50 psi ever. I run 35 tops. I need to buy a 2.5 coupler but the shipping is more than the part.
Postby PToombs » Sat Jul 26, 2008 1:38 pm
Only 35? :lol:
Philip, I don't have your number after all. All I had was the old cell number.
Postby fergavs » Sat Jul 26, 2008 2:49 pm
Vibrant is the way to go. Their web site is http://www.vibrantperformance.com/
I have used most of their product. Their silicon hoses are great. I run 45psi+ all the time and have never had an issue. Also check out their exaust fabrication components. Handy stuff to have around the shop. :thumleft:
fergavs
Postby Greenleaf » Thu Sep 11, 2008 12:26 pm
I believe the boost hoses in the TDR magazine which failed under 35 were three ply. The owner had somebody wrench on the truck and THOUGHT they were the heavy MR.B hoses to be installed. Guess not.
Blew the hole side apart.
Greenleaf
tech specialist/mod
Postby ekk33 » Thu Sep 11, 2008 4:21 pm
I would watch out on those clamps, looks like regular hose clamps, no way they are going to hold,
I will look again and see if I can find something,
1992 W250
Cooler Tubz, PS Intercooler
Pump Mods,3200 Spring,
ekk33
Postby grumpy » Thu Sep 11, 2008 6:58 pm
try these guy's for boot's http://www.sourceautomotive.biz/index.p ... t&Itemid=1 expensive but worth every penny
93 dodge w350 excab daully auto 3600 gov spring 4" streight pipe,hx-35/40 turbo
91 jeep xj trail rig I-6 5spd exo cage 7inch lift
87 35ft gooseneck trailer soon to have 79camper on it.
grumpy
