93 motor in 89 need help
Postby railhor5.9 » Fri Aug 01, 2008 5:45 pm
im new here, i live in cleburne texas, south of fortworth and dallas... im 18 ... i bought a 89 dodge with a bad ctd :( and i put a 93 intercooled motor in it works perfect i was just wonderin wat it would take for this truck to run 9.3's in the 1/8 mile... its a single cab dually 2wd with a getrag 5 speed, the 93 motor came with a auto so idk if the pump is rated lower or wat... also i have a nv4500 i wana put in it but i need an input shaft :sad: ... will the getrag hydrolics work or the nv hydros work or do i need custom ones made??? any inputs help alot... did they make any single cab duallys 4x4 i havent ever seen one...
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby railhor5.9 » Mon Aug 04, 2008 4:33 pm
anything??? :sad:
railhor5.9
Postby sdstriper » Mon Aug 04, 2008 7:24 pm
How about you look at bgilberts posts for awhile...
Your gonna need to spend some money too...
sdstriper
