strange ticking
strange ticking
Postby randyswelding » Wed Aug 20, 2008 6:33 pm
howdy guys again,so to start from the beginnin my truck started a strange tickin that i thought was a valve,i readjusted the valves again and its still doin it,you can hear it threw the grill and undernith the truck :? .but the tickin will go away thats the part i dont get.have you guys heard of this?motor rebuild soon?oh ya im in arkansas for the night before i go to the scheilds event :D and want to go do the dyno one more time to see where im at.good idea or bad idea, and how should i build this motor for towin and have lots of power.im going to oring the head how about fire ringin it, i want to see bout 45psi boost and better than 400 on the dyno,it may be a 2nd gen motor for the p pump i dont know yet thanks guys
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby gear jammer 91" » Wed Aug 20, 2008 8:54 pm
We had a gas motor that had a sticky lifter, it would tick sometimes and not others. A can of sea foam fixed it. Most parts stores have that stuff, but I have no idea if it's something you would want to put in a diesel.
01 LB7
gear jammer 91"
Postby randyswelding » Tue Aug 26, 2008 4:25 pm
i think i know what it is i got to put the stock injecters in and see if its still tickin,i think im hydrolocking pistion 1 cause it stoped makin noise when i cracked the line to bleed it today
randyswelding
Postby mprmn08 » Tue Aug 26, 2008 6:49 pm
in relevance to your first post about fireringing or o ringing. from what heard (and anyone feel free to put in there input) that fireringing is really only good for a drag race only or sled pull only truck because with firering's you have to re torque the head about every 3 months or something like that. the only benefit to fireringing (again this is what i heard) that it will hold about 30 more lbs of boost then oringing and oringing will still hold about 110 or 120.
mprmn08
Postby randyswelding » Fri Aug 29, 2008 6:23 pm
cool thanks if i can get more info on which would be better thatd be great.i want a kick butt work horse motor with enough power to go and cruise and piss off a lot of mustangs :grin:
randyswelding
Postby 92d250 » Sat Sep 13, 2008 4:07 pm
Does it have air cond. because on my 94 f350 and air cond will make a clicking noise?
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby randyswelding » Sat Sep 13, 2008 4:42 pm
it does have it for now :x but the tickin is from the rear of the engine and the back side of the oil pan
randyswelding
Postby 92d250 » Sat Sep 13, 2008 4:46 pm
idk them use a short piece of hose up to your ear and pinpoint were its at
92d250
