Anything else I should look at while I'm in there??
Thanks!
dpuckett wrote:Did the previous owner install it dry, or did he lube it up real good? The hillbilly who did the tranny in Mom's pickup installed the rear main at the same time. It leaks worse now (if that's possible) than it did before. I'd bet a case of brewed beverages that he lubed the crank first.
Daniel
dpuckett wrote: wife wont see the humor
DP
