both trucks broke
both trucks broke
Postby railhor5.9 » Tue Sep 02, 2008 10:57 am
took the motor out of my 89 to paint everything real good..... then yesterday my 03 common rail wouldnt start, tore it apart, exploded my injectors.... there $2500 for all of them, thats crazy!!!!!!!!!!!!!!!!!!!!!!!!!!! so im screwed with no truck.... guess i gotta cruise the wifeys saturn vue around for a while till i drop the motor back in the 89!!!! common rail stuff is way to expensive.... this sucks!!!
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby RumbleFish » Tue Sep 02, 2008 12:16 pm
i would probably go buy another truck
Postby PToombs » Tue Sep 02, 2008 5:09 pm
Man, for $2500, I could buy 2 1st gens! 8)
:jumpsmile:
Postby fergavs » Tue Sep 02, 2008 6:39 pm
Finding a set of tips for your injectors shouldnt be hard. Did you destroy the rest of the injector as well? How are the pistons? Any shrapnel melted into the tops?
fergavs
Postby RumbleFish » Tue Sep 02, 2008 7:36 pm
does this make anybody else appreciate 12v's even more?
Postby railhor5.9 » Wed Sep 03, 2008 2:53 pm
no its the electronic parts of the injectors..... i have to shoot it with either, hairspray or diesel in a spray bottle to make the rpms jump up and let the pump make sum rail pressure,,,, i wana sell it and get a new 1st gen.... single cab 4x4 swb,,, drop in a p-pump and a nv5600..... i got a 24 valve head 2..... throw it all together with common rail pistons!!!!!! :grin:
railhor5.9
Postby dpuckett » Wed Sep 03, 2008 3:51 pm
AInt CR pistons higher compression than stock 12V? Maybe not. I'd go for 15.3:1 marine pistons myself.
DP
