Monster Fuel Filter
Monster Fuel Filter
Postby Ace » Wed Sep 24, 2008 4:08 pm
Check out what I found on eBay for $20 - think it's big enough to flow pretty good?:
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_180.jpg
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_181.jpg
The replacement elements probably cost more than that. But I doubt it will need changed very often in my application. I'm going to use this as the 10 micron pre-filter between the tanks and the lift pumps, I just have to make a mounting bracket, relocate the tank selector valve and do a little plumbing. It will be mounted up under the left front corner of the bed. I'll post some pics with a little writeup in the projects when done. :grin:
Ace
