I would like to tweek my truck for better fuel economy
Postby bikeboy1713 » Fri Sep 26, 2008 9:16 am
I use my truck mostly as a play truck. I am currently getting 17.75 MPG empty and 13 towing my 20' camper. (when I am easy on the skinny stick). I have my pump set with the fuel pin at the deepest setting, and star wheel all the way out . I removed the collar from the fuel screw and turned it all the way in till it it stopped turning. After doing this the fuel mileage didn't change but the power went waaay up. The truck will smoke before the turbo spools then clear up right away. If I really mat it I can lay quite a cloud of black smoke, although I am careful not to do this for too long as I don't want the EGTs to get too high.
Here are the questions
Would installing 185 or 190 injectors help my fuel mileage (6 holes instead of 4) without hurting my power.
How much gain do you think that I will get with a Hughs torque converter
I still haven't advanced the timing. How much does that help.
If anyone has any other good ideas for fuel economy please let me know.
I don't want to spend tons of money on the truck but if I spend the money and get results most of it should come back as fuel savings.
Don
1991 W250, 727, 3.07, fuel screw cranked, 3200 spring, pin turned, pyro.
bikeboy1713
Postby CumminsPride » Fri Sep 26, 2008 9:51 am
I think the best iprovment you could make would be a 5spd conversion. Better than spending the dough on converter and injectors. You should be able to find a decent donor for 1500 or less.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby fourwheelininajeep » Fri Sep 26, 2008 10:57 am
Timing plays a huge part I bumped mine all the way to the head advanced and it improved hugely for power and throttle response. I was getting 19 with a 5 speed and a stock pump, I turned my fuel screw in 2 turns and put a set of same as stock size holes but different spray and advanced timing im getting 23 on a non intercooled. Super high egts if a punch it but I keep it out of the throttle mose of the time
1990 dodge w350 cab and chassis frame single rear wheel 99000 miles with chrome stacks between cab and bed paid 1300 for it after a years worth of work i got to drive it
fourwheelininajeep
