sucking air or ?
sucking air or ?
Postby dragrdan » Thu Oct 02, 2008 7:19 pm
Last week, driving home from work, cruising down the highway ~70mph, my truck died and wouldn't restart. Fuel gauge showed 1/4 tank. The truck is still somewhat new to me, so i thought the gauge was off. Had someone bring me some fuel, put it in, primed and bled the system and it fired right up. Drove it straight to a station and filled it up. Only took 22gals to fill it so guage seems accurate? Ran fine until 2 days ago, again driving down the highway ~70mph it died. Primed and bled it and it started and ran fine. This time the gauge showed a little over half. Today, same thing, died, primed it and bled it out, and made it home. Everytime it died, it started blowin white smoke as it was dying.
Truck is a 93 W250 5sp. Starts right up first crank(except the times it has died on me). Could there be a small enough leak in the suction side of the fuel system that air builds up and gives me problems. I put 350 miles on it between the first and second time it died, and about another 100 between the second and third time. Also thought maybe the lift pump, but oil is not filling, and doesnt smell like fuel(has the diaphragm type).
Spring could be getting weak, but would this cause it to lose prime?
Any tips for checking for leaks in the suction side, there are no wet areas, or leaks that I can see. Truck still has the factory plastic lines, are they still available or will I need to fab something up?
Sorry so long winded, but wanted to give as much info as I can.
Thanks in advance
dragrdan
