heads
heads
Postby randyswelding » Sun Oct 12, 2008 6:04 pm
when i go to do this motor,what should i do with the head,port and polish,oring(do i need it i want to run an s300 62/65/13 combo)bigger valves and push rods?it does still need to be a work horse(today with trailer 20 bails of hay :D and not a problem but stoping no trailer brakes :shock: )what do i need to do to make this motor eficiant and powerful oh ya and id like it to smoke a little(remember im still a grasshopper :D )
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby randyswelding » Sun Oct 12, 2008 7:45 pm
any one runnin or know anyone runnin a fully loaded head from pure cummins diesel performance?is that a good company to get things from?
randyswelding
Postby bgilbert » Mon Oct 13, 2008 5:09 am
For all that, stock sounds good to me.
Bill Gilbert
bgilbert
Postby randyswelding » Tue Oct 14, 2008 3:00 pm
right bill,but what do i need to do to it to make it able to hold the power and still be reliable
randyswelding
Postby fergavs » Tue Oct 14, 2008 11:21 pm
I would at least ring and stud the head. It is relatively cheap insurance, especially if you value your time. If you have some time while its apart pull out the die grinder and diamond bit and cut away at the rough castings in the exaust ports and smooth out the transitions where you can reach. Also pull out your new exaust gasket and port match the exaust manifold and the head. If your to busy just put the ringed head and new studs together and be happy. The port work is not really worth paying someone to do but to do it your self is great. (I got a real good deal on mine 8) )
fergavs
Postby jimmyt83 » Wed Oct 15, 2008 5:08 pm
A lot depends on what else you're planning on. How big of an injector you're planning on using...turning the pump up (i know it's a given...) and so on and so forth. If I'm understanding the others' thoughts on it all...as long as you're not pushing more than about 40 lbs of boost or so and not constantly abusing it, you are safe with stock head gaskets.
jimmyt83
Postby randyswelding » Wed Oct 15, 2008 6:20 pm
ya but my foot is kind of heavy :D ,i like feelin the power my truck has when i can hit a scale and weigh in at 11klbs.if you see how i drive when i want to have fun youd say i abuse it a lot :oops: thats another thing i got to work on.id like 400 hp and a motor i can take to hell and back and then still get to hooters and still live with out skipin a beet
randyswelding
Postby fergavs » Wed Oct 15, 2008 7:42 pm
Welcome to the fantastic world of owning a cummins sir. LOL. As you said to hell and back and still running strong.
fergavs
Postby randyswelding » Thu Oct 16, 2008 5:26 pm
haha :D and i want 400hp and do it constantly :lol:
randyswelding
Postby fergavs » Thu Oct 16, 2008 6:14 pm
Mine is probably in the 500hp range (fuel only) and I drive it regularly and flog the heck out of it every chance I get. I tow an enclosed car hauler (up to 12000lbs) almost every week and I am about to drive it 1400 miles across the country. I would say that is full on regular use. This is all on a 14mm head as well. Thats what I love about these trucks. They are super reliable even with heavy mods. We shall see if the 14mm holds together over the long haul but I am confident.
The 400hp isnt that hard. Just do a 62/71/14 or 64/71/14 turbo and you should be there. For either of those turbos I would run studs at least thou.
fergavs
Postby randyswelding » Thu Oct 16, 2008 6:58 pm
ok thanks let us know how your trip goes :D
randyswelding
