freeze plug size??? where to get
Postby mtm93ramnasty » Thu Oct 16, 2008 8:58 pm
ive been goin nuts tryn to get the right size freeze plug i measured it and it seemd to be 2 5/16, but i went to the parts store they said its 2 1/4. i put the 2 1/4in and seald it...i startd it up no leak untill i floord it, the damn thing blew right out. also wheres the best place to go to get one ive been to napa, a local auto parts stoor, sg diesel, and my brother works at a mechanics shop and couldnt get one. would advanced auto have the right one? what about a cap for the end of a pipe if i could get the right size
93 ctd pump maxed, little bit of timing, fuel pin ground, 3200 gov spring, 6x18 injectors, hx40, CoolerTubz, southbend con fe, isspro guages boost+pryo, 5in exhaust, home made intake w/greens airfilter
340hp 739tq no ksb hot wire stock lp
mtm93ramnasty
Postby Fnschlaud4620 » Fri Oct 17, 2008 4:49 am
Have a local machine shop make you a set of these...Image
Or you can buy them from Pure Diesel Power for $40.00 each.
Fnschlaud4620
Postby mtm93ramnasty » Fri Oct 17, 2008 10:24 am
yea i think im gonna go with the haisley ones from pure diesel ive been lookn at them
mtm93ramnasty
Postby bgilbert » Fri Oct 17, 2008 1:15 pm
Old block heaters work great as well.
Bill Gilbert
bgilbert
Postby PToombs » Fri Oct 17, 2008 5:07 pm
Most of the plugs on our engines are 58 mm. Can't get them at NAPA or the crappy auto parts stores. Cummins or a Case/IH dealer.
Postby mtm93ramnasty » Fri Oct 17, 2008 6:43 pm
lol my next stop was gonna be a trackr dealer but thanks for the block heater idea just hapns that i have a spare cummins took the heater out and shes running good! im leavn early tomorow morning to get it on the dyno i dont think its gonna make that much power it runin out of fuel but it will hit 49lb of boost so well see what hapns hopefully ill be close to 400 but im thinkn more like 350
mtm93ramnasty
