Best price on piston lift pump, and current part #?
Postby Bookshelf » Mon Oct 20, 2008 3:12 pm
Does anyone know who's got the best price on a piston lift pump(low psi first gen type) and what the current part # is? Thanks-Nick
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby 1991cummins » Mon Oct 20, 2008 6:42 pm
these are the Cummins part numbers:
# 3936320 lift pump (qty 1)
# 3914753 Fuel Line (qty 1)
# 3931348 Gasket (qty 2)
# 3914284 Spacer (qty1)
# 3918191 Seals (qty 2)
and i have heard that putting a "w" or some letter at the beginning of those part numbers and you have a case part number for the exact same part... dont quote me on that though, maybe somebody else knows...
1991cummins
Postby RumbleFish » Tue Oct 21, 2008 1:36 pm
change the first 3 to a J and head to the cse/ih dealer. much cheaper. when i bought everything but the LP itself and the total came to $45 and change.
