Cold start vid
Cold start vid
Postby bgilbert » Sat Feb 03, 2007 10:56 am
Have had this digital camera for over 2 years and just now figured out it has a movie/video option :? . Here is one, horrible quality, but I'll work on getting better ones. This is a 18* cold start, no grid heater, no ether, truck been sitting for 30 days. http://www.youtube.com/watch?v=v4QMd4SOtI8
Bill Gilbert
bgilbert
Postby 92 D/UNIT » Sat Feb 03, 2007 11:29 am
my heater grid is gone on mine, forgot to plug it in the other night at 20 deg took a couple tries but started up pretty good.
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby PToombs » Sat Feb 03, 2007 2:55 pm
I just started mine an hour ago. 25*, one run of the grids, not plugged in. She spun over half a dozen times before she took off. Been sitting almost 2 months now. Once it fired, it took off pretty smooth. 8)
I had to move it before I lost it in the snowbank! :oops:
Postby Cowboy_Customs » Sun Feb 04, 2007 5:09 pm
I was going to get a cold start Vid. but the digital has been in the Freightliner and killed the batteries in the digital do to the cold. But mine wasent started for about 2 weeks, I went out n fired it up Friday morn. n fired right off maybe 1 crank, BUT now my Batt. is on the way out, so shes getting sslllooowwwww but still one full crank, and a little blue haze till its satisfactorilly (is that a word?) warm enough to leave. then the haze clears up.
Lost, but not forgotten. '93 Dodge D-350 regular cab 2x6, 5-speed, Phantom Pyro, LED guages, Polished valve covers, 366 spring, 4 inch Rip DP, to 6 inch stacks, lots 'o lights
http://community.webshots.com/user/Cowboy_Customs
Cowboy_Customs
Postby Flanra » Tue Feb 06, 2007 12:08 am
I know alot of powerstroke guys that only wish their trucks could do that....
1990 1st gen, 727 auto, starwheel bottomed, fuel delivery rate adj. fuel screw turned, 4" exhaust/stacked, pyro/boost 35# @ 1250*... 3" lift 36" tires...
http://s119.photobucket.com/albums/o151/flanra/Truck/
Flanra
Postby JD730 » Tue Feb 06, 2007 1:14 pm
Last year when my PCM was giving my problems the grids wouldn't work when it was cold. My dad had 5*F up in Beaver Dams, NY and started it, took three tries, but it started. He called me to complain, but stopped when I pointed out that if it happened to our ford he'd probably have to wait till spring to get it started.
Mike
The "Rattle Box"
JD730
