Advancing the timing on a '93 VE pump Cummins.
Postby 92 D/UNIT » Sat Feb 24, 2007 10:48 pm
I have messed with my timing more than i can count with both hands and have not had a problem, if you are worried about cracking a line, loosen them at the back of the pump and tighten them back up when your done setting your timing. :D
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby wannadiesel » Sat Feb 24, 2007 11:21 pm
Yep, but they are not bent, at least not in the sense that you have passed the limit of their elasticity. Does that make sense? :?
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Sat Feb 24, 2007 11:47 pm
How much of a hassle is it to loosen and reattach the lines?
If it was a problem I'm sure ya'll would now, but from where I come from a vibrating pipe with tension applied to it is more likely to crack then the vibrating pipe without the tension. The latter pipe absorbs energy by moving back and forth; the one with tension on it can't move, so instead it shears itself in half... Just sort of strikes me as wrong...
