BANJO BOLT?
BANJO BOLT?
Postby CAJUN 93 » Thu Feb 08, 2007 12:55 pm
i'm installing my piston lift pump this weekend. yesterday while staring at the engine getting my mind straight, i noticed that the banjo bolt on the outlet side of the filter housing (right next to the pipe plug i removed to tap for the boost gage) has a small (appears to 1/8 pipe) plug in it. is there any reason i can't remove that plug and tap a fuel pressure gage into the banjo bolt? looks to me like it would work.
thanks
CAJUN 93
Postby KTA » Thu Feb 08, 2007 1:39 pm
I think you will find that bolt is a 6mm o-ring thread, not an 1/8NPT. I think there is enough material in it to tap it to 1/8 NPT though.
Postby CAJUN 93 » Thu Feb 08, 2007 2:43 pm
thanks, i'll pull it out this weekend and see what i can do.
CAJUN 93
Postby PToombs » Thu Feb 08, 2007 2:58 pm
Most of them have a 4 or 5 mm bolt in there. If it has a pipe plug, somebody has already been at it. I bought a new one and drilled and tapped mine. The bolt is VERY hard. I could not go very deep with the tap. If you go too deep, you will be thru the top of the bolt, into the shaft. The ones from Genos have a thicker head. I also drilled out the banjo bolt side holes on both bolts, for more flow. :D
Postby TOMTOM » Thu Feb 08, 2007 7:10 pm
It is a 6mm. Is this a ok place to read fuel pressure?
93 CLUB CAB LE SHORT BED 209,000 MILES AUTO/OD 3.54 GEARS 4" TURBO BACK EX NO MUFFLER P7100 PUMP MODS B/D INJECTORS 13.55@99 MPH 440HP 967TQ ON #2 ONLY. PSD INTERCOOLER,BD SUPER B TURBO)47RE FULL MAN SUNCOAST TRIPLE DISC
TOMTOM
Postby Paccool » Thu Feb 08, 2007 10:54 pm
I have my fuel pressure gauge hooked up there, works fine. I got one of Geno's bolts and installed it rather than fool with the stock one.
Stan
93 D250, PDR cam,stage 2 head w/o-rings,twin turbos HX35 on top HT3B on the bottom,modified IP,piston lift pump,DDP stage 3 injectors,gauges,ATS ported manifold,4" exhaust,5" inlet system,oversized intercooler, rear sway bar, fresh paint
Paccool
Postby Greenleaf » Fri Feb 09, 2007 1:17 pm
I have performed both methods. My conclusion is "time is money"
Greenleaf
tech specialist/mod
Postby wannadiesel » Fri Feb 09, 2007 3:40 pm
Greenleaf wrote:I have performed both methods. My conclusion is "time is money"
Amen to that. And if you want a 1/4" NPT tapped banjo (for feeding an auxiliary pump) GDP has those.
Best dyno: 408/844
wannadiesel
diesel guru
Postby CAJUN 93 » Fri Feb 09, 2007 3:53 pm
point taken :)
CAJUN 93
Postby andyr354 » Sat Mar 10, 2007 8:26 pm
I picked up a "fuel injection pressure test kit" last time I was in HF. It has the correct metric o-ring adapter in the kit to use on the stock banjo. It is usefull for testing, but for a permanent guage I would get the ones from genos or similar.
93 W250, Getrag, 3.55 gears, BHAF, Fuel screw against lock collar, AFC set to deepest point, stock straight pipe, timing bumped 1/8", Isspro boost/pyro/tach, 220K+ miles.
andyr354
