Truck died on the way home yesterday
Postby eyoung429 » Sat Feb 10, 2007 8:09 am
Can I use a holley electric pump for a lift pump to get the rig back home? I also have a regulator with guage.
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby KTA » Sat Feb 10, 2007 9:36 am
If the transfer pump is your problem you can use the holley no problem, even un regulated as most holleys max out at 16psi and the VE can easily withstand that.
Postby eyoung429 » Sat Feb 10, 2007 9:38 am
Cool.....I am going to head up there and see if it is a relay that went out or if it's dead.....
Thanks!
eyoung429
Postby 2stroke » Sun Feb 11, 2007 6:56 pm
mine did the same thing the other day. got it started and home. couldnt get it started again after that. ended up puting an injector pump on it. :cry:
2stroke
Postby Paccool » Mon Feb 12, 2007 12:22 pm
Sounds like the fuel shutoff solenoid may have gone south on you. If they go out, the truck will die like you turned the switch off. If you cycle the ignition switch on and off you should be able to fel the solenoid cycle. If it is out, you can get the truck home by pulling the solenoid off and removing the plunger and spring. Put the solenoid housing back on and see if the truck will start. If it does, the way to turn the motor off is to use the shutoff lever on hte side of the pump.
This is a common problem with these trucks.
Stan
93 D250, PDR cam,stage 2 head w/o-rings,twin turbos HX35 on top HT3B on the bottom,modified IP,piston lift pump,DDP stage 3 injectors,gauges,ATS ported manifold,4" exhaust,5" inlet system,oversized intercooler, rear sway bar, fresh paint
Paccool
Postby eyoung429 » Tue Feb 20, 2007 12:05 pm
Thanks guys! Couldn't id the solenoid as one of the wires broke off. Fixed it and ran her for a bit before she decided to swallow chunks of the air filter.
lookin' fer a terbo now.....
eyoung429
Postby eyoung429 » Wed Feb 21, 2007 6:33 am
What are the options for a garret turbo as a replacement unit? say a t/3 t/4 A/R60?
eyoung429
Postby dpuckett » Thu Mar 01, 2007 11:10 am
Huh? Can you translate that for me? My knowledge is limited, and when you get outside the Cummins realm, I'm lost.
What's wrong with the Holsets? Not trying to pick a fight or run you down, but just wondering. The Garret turbos require water cooling as far as I know, or many of them do (more opportunity for leaks, clogging, etc). The holsets are designed for the engine as an OE fit, why do it different if you dont have to? Unless you are after a BB turbo or something of that ilk.
Daniel
Postby eyoung429 » Thu Mar 01, 2007 3:07 pm
I had some other opportunities to purchase one cheaply and was going to go that route if need be....case of I want to get her back on the road and couldn't find another holset at the time.
eyoung429
Postby BEARKILLER » Thu Mar 01, 2007 3:50 pm
dpuckett wrote: The Garret turbos require water cooling as far as I know, or many of them do (more opportunity for leaks, clogging, etc).
All the Garretts I have owned looked and operated no different from the Holsets on the Cummins.
Maybe a different bolt-pattern, not sure, but now that the question has came up, I will lay a Holset gasket on the flange of one of the Garretts and see how they differ.
#4 = 1991 D-350 LE Getrag
BEARKILLER
