Silly question...How long can air be trapped...
Postby aspoonhour » Tue Jan 13, 2009 6:27 pm
...in an injector line or injector?
Can air stay in an injector or line indefinately or can it disapate over time?
aspoonhour
Postby Begle1 » Tue Jan 13, 2009 9:43 pm
If there is air in the injector line when the truck is parked, and you wait 6 months, there's still going to be air in the line when you come back.
Once you get it started, the air should dissipate out of the lines by itself.
Postby sdstriper » Tue Jan 13, 2009 10:42 pm
Should... I have had air stay in the fuel system after hours of running the engine at idle. Thinking it would kick it out thru the return lines. The only way I got it out so the truck would run and drive decent was to loosen the injector nuts an watch the fuel until no bubbles were visible.
sdstriper
Postby aspoonhour » Thu Jan 15, 2009 7:47 pm
Thanks guys...
aspoonhour
