Eliminating intake heater
Postby DALEDOZER » Tue Feb 13, 2007 7:10 pm
I've been having problems with my intake heater, sure you guys heard it before, intake heater won't come on, alternator won't charge, WTS light won't go out and flickers. So I removed the relays, heater, spliced wires together at temp sensor on intake manifold, cleaned tach. harness along with a few others. Only when I start it, there is no charging from alternator until it gets warm, sometimes as long as a half hour then just starts charging. Once its warm you can shut it off and start up again and will charge. I would just like to bypass the intake heater all together, how do I do this?
1992 250 4X4, 5spd, HX40, 435s, 3200 gov. Snow Perf. Stg.2, 6" stacks, 4" skyjacker lift, 315 Yokahama Geolander M/Ts, borgenson shaft, piston LP, 7.3 intercooler.
DALEDOZER
Postby bgilbert » Tue Feb 13, 2007 9:00 pm
Sounds like you have other issues, but I will tell you how to do away with the grid heater. Simply unplug the 4 small push-on wires at the grid heater relays on the d-side fenderwell.
Sounds like bad ground, pcm or crank sensor issues. I'm not the expert there though.
Bill Gilbert
bgilbert
Postby JD730 » Wed Feb 14, 2007 11:44 am
Sounds like a PCM, I've had 2 out of my 3 do it to me so far. They work fine when its warm, but cold forget about it.
Mike
The "Rattle Box"
JD730
Postby DALEDOZER » Wed Feb 14, 2007 6:27 pm
Can the PCM be eliminated?
DALEDOZER
Postby bgilbert » Thu Feb 15, 2007 6:02 pm
I think you'd have to convert your alternator to an external charging type along with a external voltage regulator. I'm no expert there though.
bgilbert
Postby TWorline » Thu Feb 15, 2007 8:31 pm
Dale:
I think that Bill is right about the charging system, the speedometer/odometer may be affected as well along with the factory tach, if so equiped. Other than those things I can't think of any thing else that it would affect.
Tim Worline
http://www.CoolerTubz.com/
TWorline
