Vibrrrrrrration at idle.
Postby JSBlack » Fri Jan 30, 2009 8:30 am
Hi All,
1st post for me. I found you guys noted at the end of an article in the Feb '09 Diesel Power magazine..
I have a 90 1-ton 4WD Cummins. Since I got it I have dealt with a pretty significant vibration at idle (the mirrors shake, the change in the ashtray jingles, gotta shut off the engine at the drive-thru). The friend I got the truck from, said he set the idle lower "to quit breaking u-joints" while towing.
The vibration goes away with the slightest bit of throttle. I had the idle dialed-up to about where it should be, but where it smooths out is just a bit higher than it should be set to. It seems worse in drive than in park or neutral.
I have shown it to two qualified diesel mechanics, and three diesel-savvy amateurs. The mechanics say it is fine. This seems strange to me: do they not want my money? Furthermore, I don't think anyone would buy a new truck, even in 1990, that vibrated so...
The amateurs say 1) harmonic balancer problem, 2+3) Bad motor-mounts, and that a harmonic balancer problem would not just be apparent at idle. I have looked at the motor mounts and they don't seem visibly degraded to me, or missing.
I suppose it is possible that the motor mounts are so hardened with age that they aren't functioning correctly. Should I replace them as a relatively cheap way to narrow-down my problem? If so, stock rubber or fancy polyurethane (if they even make those for the old 12v Cummins??)
Anyone have any suggestions? I love this truck and want to keep it a long time. I hate to think they are missing something critical and that I am doing damage to it driving...
Thanks in advance,
-John
'90 single-axle 1-ton, 4WD, sgl cab. Flatbed (for welder). Diesel, of course!
JSBlack
Postby RSWORDS » Fri Jan 30, 2009 8:58 am
turn your idle back up. these trucks will shake them selves apart at idle when the idle is to low. It should be around 750-800.
It would be worse in drive then park because the tranny will pull the engine down a few RPM.
To check the engine mounts put the truck in drive. Hold the brake real hard and hit the throttle. See how far the engine rocks.
RSWORDS
Postby Farmboy » Fri Jan 30, 2009 9:13 am
My truck does the same thing. My truck has a fast idle cable hooked up to the peddel. I don't know if this is factory or aftermarket but if I need it to quiet down I just bump up the idle. although the cable it mainly used to warm up the truck in cold weather.
Farmboy
Postby randyswelding » Fri Jan 30, 2009 9:13 pm
ok 2 things i got to know where in ok are ya at and what kind of welder,and are they hirin where ya work?ok so 3 things welcome to the form,i found that my 92 has a bad vibration at 750 rpm to 800 and right now im at 950 its high but smooth and nice for the winter too.
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby JSBlack » Sat Jan 31, 2009 11:55 am
Thanks gang!
For the welcome to the forum, and all the good advice. I will check back in on this string with a followup...
-John
JSBlack
Postby RumbleFish » Sat Jan 31, 2009 2:58 pm
does your truck have mirrors like this on it?
if so, you can use a trick i picked up from pastor bob. start your truck, make sure its in neutral or park. turn the idle up until the mirror stops shaking and you can see a clear reflection in it. strangely enough, its right about where the factory spec should be.
Postby Ace » Sat Jan 31, 2009 4:21 pm
Mine idles at 850. I think the 750 stock spec is too low. That might be hard on an automatic trans, tho.
Ace
Postby peobryant » Sat Jan 31, 2009 9:37 pm
Ace wrote:Mine idles at 850. I think the 750 stock spec is too low. That might be hard on an automatic trans, tho.
Quick question, why would a higher idle be hard on an automatic? I'm not doubting you, I'm just curious.
Postby Richie O » Sat Jan 31, 2009 10:06 pm
It goes into gear harder. BANG!
Postby peobryant » Sat Jan 31, 2009 10:10 pm
Richie O wrote:It goes into gear harder. BANG!
Well I was expecting a long, confusing explanation, but that makes perfect sense. I should've known that. :oops:
