leakin shut off lever and no shut off
Postby randyswelding » Mon Feb 09, 2009 8:33 pm
ok to start with this i have a shut off cable going to the shut off lever and it had some slack in the cable,so i loosened the nut for the lever(for the bolt head is on the inside of the lever) and tightened the cable up and fallowed that by tightening the lever nut.started the truck and tried the cable and nothin,still ran but didnt pull out as far which is what i wanted but still ran and when i felt around the lever it was leakin fuel.i did see the oring behind the lever and spring but is there another one on the inside and what in the heck did i do.tomarrow i got to go and get my tools from where im workin on my other motor to get the top off and see whats goin on.thanks for any help
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby TWorline » Mon Feb 09, 2009 9:43 pm
Randy:
Take a look at post #17 in this link it shows the shut off lever, seal and washer assembly and you can see that it moves the fulcrum lever to shut off the fuel. http://www.dieseltruckresource.com/dev/showthread.php?t=200901&page=2
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby randyswelding » Mon Feb 09, 2009 9:56 pm
Where is the fulcrum lever at on the top of the pump hopefully cause I got another top from my new old pump
randyswelding
Postby gear jammer 91" » Mon Feb 09, 2009 10:47 pm
If I understood you correctly, you moved the shut down lever on the outside of the pump to take slack out of you shut down cable?. If so the lever on the inside of the pump is probably not in the right place in relation to the lever on the outside, and therefore you are not getting the movement necessary to move the previously mentioned fulcrum lever and stop the flow of fuel.
If you have another pump top, look at the position of the lever on the outside of the pump top in comparison with the lever on the inside. If you pull your pump top off of your truck I think you will see that the two parts of the shut down lever are not located properly, and all this rambling might actually make sense. :lol: Good luck. :)
01 LB7
gear jammer 91"
Postby randyswelding » Tue Feb 10, 2009 6:47 am
Ok then that makes sense then I didn't think I moved the shaft.or at least thought it didnrt move.I got to get ny tools back to the house and then play with. Both my pumps again. Thanks guys
randyswelding
Postby randyswelding » Tue Feb 10, 2009 10:14 pm
yap just needed to be reindexed is all thank god,i did pull the top off to see if any thing broke or was out of place and to aid in puting a new dang oring,thanks guys on to my new but old problem :x
randyswelding
