How much timing do you have? If you don't have fuel specs in your signature, please add them to the post.
I'm curious how much fuel you guys are running at how much timing.
I'm trying to figure out why my EGT's climb really fast when I hit 3k rpm. I had someone tell me my timing was too advanced, then tell me it was also because I was running 5 gallons of motor oil per tank. The higher flashpoint of the oil was slowing down the burntime, and going out the exhaust.
I just thought I was out of the map range of the turbo, H1C, Stage IV kit, and 16cm exhaust housing.
 .  My auto truck is to the head and idled great with the bigger EDM's in it, but now that the stockers are in it, it sounds not so great, like a 24 valve
