Leaking WIF Sensor
Leaking WIF Sensor
Postby cedardiesel » Sat Feb 21, 2009 7:46 pm
I got a problem with my Water In Fuel sensor leaking and I have replaced the sensor itself because the original one was leaking also. I have been running the solid bottom filters for some time and didn't have a problem but would like to have the sensor operable just for the peace of mind that if I happen to get a bad batch of fuel. Any help or advice is greatly appreciated.
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby sdstriper » Sat Feb 21, 2009 7:48 pm
Make sure it is not the square cut o-ring seal on top of the fuel heater.
sdstriper
Postby cedardiesel » Sat Feb 21, 2009 7:52 pm
Is that the one that you put on before you put the filter on cause if so t isn't leakin cause the filter is completely dry and clean of fuel.
cedardiesel
Postby sdstriper » Sun Feb 22, 2009 2:10 am
It is above the fuel heater between the heater and the head.
sdstriper
Postby cedardiesel » Sun Feb 22, 2009 9:53 am
You wouldn't happen to know the part # for that o-ring cause went and checked again and it looks like that very well be my problem.
cedardiesel
Postby sdstriper » Sun Feb 22, 2009 11:54 am
From Cummins Quickserve p/n 3913695 rectangular ring seal...
sdstriper
Postby cedardiesel » Sun Feb 22, 2009 7:29 pm
Ok thank you I try and see iff that will solve my problem.
cedardiesel
