pushrods
pushrods
Postby EARLBURNER » Mon Feb 23, 2009 7:41 am
I was tearing my 89 non ic cummins down this weekend and found that most of my pushrods on the intake side were bent. The exhaust side looks fine. What would cause this?
EARLBURNER
Postby okish » Mon Feb 23, 2009 10:48 am
Bet its a 5 speed.... the cause is most likely engine over speed.
89 D250- G360, Bombed VE, BHAF, 4 inch turbo back, 60mm h1e/h1c hybrid, 16cm3 pdr ported housing, custom 2.5 inch crossover pipe, denny t stg 2 fuel pin, piston lift pump.
okish
Postby KTA » Mon Feb 23, 2009 4:22 pm
There is a ton of clearance in these motors stock, more than enough that you shouldn't bend any pushrods. Sounds like the camshaft was out of time. Sheared keys, broken gears, missing teeth, somebody installed it wrong?
Postby cummins king » Mon Feb 23, 2009 10:05 pm
mine were ever so slightly bent too. i was because im sure the truck hasn't had a valve adjustment since the truck was new, plus a bit of over revving.
93 4X4 auto
cummins king
Postby EARLBURNER » Tue Feb 24, 2009 7:45 am
I had two pushrods that wouldn't spin 360 degrees and one that rubbed a groove in the inspection plate. The engine was mated with a 727. Will be mated with a 5 speed now. It came out of an 84 quad cab 2wd dually chevy, so I have no idea of the history of this engine. All gears on the front of the engine are in good shape (oil pump,idler,crankshaft,cam,injection pump gears) . Im buying all new pushrods hopefully to remedy all my problem. excessive rpms.... how fast is too fast to spin the engine... must be over 3200????
EARLBURNER
Postby Begle1 » Tue Feb 24, 2009 7:50 am
Seems to me like the aftermarket pushrods get used to prevent these problems.
Postby EARLBURNER » Tue Feb 24, 2009 7:52 am
where do i find the aftermarket pushrods? Ive already ordered stock ones, but can still return them?
EARLBURNER
Postby KTA » Tue Feb 24, 2009 10:41 am
Interesting. I have a p-pumped pulling motor that turns over 4500rpms everytime down the track, runs about 50psi, a very aggressive cam and still has the factory stock pushrods from back in 1995 200,000 miles ago. It must be because it has good valve springs that it has survived. Old yellow also has stock pushrods and runs 70+psi and turns 4200rpm or so, but it has good springs too.
Postby Begle1 » Tue Feb 24, 2009 10:54 am
EARLBURNER wrote:where do i find the aftermarket pushrods? Ive already ordered stock ones, but can still return them?
I believe there are several manufacturers.
http://www.competitiondiesel.com/forums ... hp?t=37297
http://www.competitiondiesel.com/forums ... hp?t=32432
http://www.competitiondiesel.com/forums ... hp?t=24475
Seems like some engines like to bend them at high RPM and some don't. But considering that there is a lot of guys making, selling and running them, it leads me to think there's something to them.
What valve springs do you consider "good"?
Postby EARLBURNER » Tue Feb 24, 2009 12:50 pm
so if im not going to turn more than say 3200rpm would you think i would need upgraded push rods
EARLBURNER
Postby Begle1 » Tue Feb 24, 2009 9:42 pm
No, I've never heard anybody recommend them for a 3200 RPM engine..
Postby fasttalker83 » Tue Feb 24, 2009 10:01 pm
Something to think about I almost bought HD frozen reheated tempered push rods cuz I didnt want to bend a rod in my puller but a man steered me away from it when he got me thinkin about what else would break if my pushrod didnt.....its easy and fairly cheap to replace a push rod or two its not so cheap when you have to get the head sent off and a new valve job done on it or valve hitting the piston etc. whatever the case maybe I believe it could cost you in the long run just a thought
fasttalker83
Postby ctd6spd » Wed Feb 25, 2009 8:00 am
We got the OE replacement push rods for earlburners motor put in yesterday, can some one tell me the torque specs and sequence for the Big and Little bolt on the rocker Arm support? As I assume the big one is one of the head bolts. Thanks guys.
2002 2WD Silver 3500 DRW and
93 12V IC and getrag going in a 89 C30
ctd6spd
Postby ctd6spd » Wed Feb 25, 2009 8:31 am
I found it thanks again.
ctd6spd
Postby Ace » Wed Feb 25, 2009 10:06 am
Begle1 wrote:What valve springs do you consider "good"?
Any ones that are not worn out, to start with. 60# better, last longer before worn out to the point of leading to things like bent pushrods.
Ace
