Pan gasket
Pan gasket
Postby Renigade » Mon Mar 02, 2009 8:07 pm
Can the oil pan gasket be changed without lifting the motor some?
1993 1st gen BHAF -Smoke screw 2.5 turns, star wheel 2.5 turns. Fuel screw 1.25 turns, fuel pin ground.
Renigade
Postby randyswelding » Thu Mar 05, 2009 8:18 am
all depends on 2wd or 4wd
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby BC847 » Thu Mar 05, 2009 8:55 am
4x4 ~ yes. It's tight but doable. ;)
Postby acs_beau » Tue Mar 17, 2009 10:27 pm
Does that imply that the 2wd needs the engine lifted?
acs_beau
