gear jammer 91" wrote:Begle ain't jokin! If it won't idle smooth after you screw with the screw, shut er' down and back the screw out a little, if you blip the throttle it will run away on you. Ask me how I know.
Richie O wrote:Will the manual shut off kill a run away? Or do you need to board the turbo?
