Holley Blue
Holley Blue
Postby MudSlinger79 » Mon Mar 30, 2009 6:56 pm
I know u guys talk about running holley blue pumps do u run them in tandem with the factory lift pump? Or run it strait to the fuel filter?
93 Ford, 1st Gen Cummins, 66/71/14 S-300, New Era 435 Sticks ,Pump Cranked, denny 2 fuel pin, afc MIA, 3200 spring. Sitting on 5 Ton Rockwells With 63" Rice And Canes. More To Come!!
MudSlinger79
Postby gear jammer 91" » Tue Mar 31, 2009 4:30 pm
When I was going to run a holley electric pump, I was going to run it solo. I was also going to go with the black pump because it flows more gph at the same pressure. After talking to a couple people I decided to go with a mechanical pump because my truck is a daily driver, and there seems to be some reliability issues with the holley pumps. Not everybody I talked too had issues, just enough that I decided to go in a different direction.
01 LB7
gear jammer 91"
Postby MudSlinger79 » Tue Mar 31, 2009 7:15 pm
well right now im running it in tandem but just wondering if im doing any good or bad?
MudSlinger79
Postby Begle1 » Tue Mar 31, 2009 9:56 pm
"Tandem" as in series, or "tandem" as in parallel?
Postby MudSlinger79 » Wed Apr 01, 2009 4:49 am
series
MudSlinger79
Postby Begle1 » Wed Apr 01, 2009 11:13 am
Aren't there Holley pumps that need to be regulated down? I would like a Holley due to price and availability, but I'd like something that might be able to put out 30 PSI or so if I'd ask of it.
