Dead Bunny wrote:As soon as I hook the injector lines back up and crank it over, I can see massive amounts of air coming out of the IP return line (obviously back-flowing from the injectors).
Begle1 wrote:Sounds like a job for the ether bunny.
Just got myself a can. I'll be trying it as soon as there is not a monsoon outside.
Begle1 wrote:It's, like, 80 degrees out here. You mean some parts of the country are cold enough to still have grid heater weather?
TWorline wrote:Just got myself a can. I'll be trying it as soon as there is not a monsoon outside.
If you try ether unhook the heater grid relays that are mounted on your fender well, your head gasket will like you.
dpuckett wrote:Good. Glad you got it running. What did it?
