beerboy81 wrote:other then the white smoke, is there any way you could tell if the grid isn't working?? im still investigating if its the grid OR the relay is shot??
when i first start it up cold, i can hear and feel a "CLICK" like every 10-15 secs and the battery gauge goes back n forth every click. i thought that was weird! any ideas, anyone?
KTA wrote:It sounds like you are getting air in the system from somewhere. Anyplace fuel leaks out is a place air can get in when it isn't running. Air is compressible, diesel fuel is not, so it plays havoc with lots of things when it gets in to the system. You can start with fixing your pump leaks, but I have also seen lots of problems back at the sender on the fuel tank getting rusted and letting air in.
beerboy81 wrote:ksp? ip? i have white smoke sometimes when i stomp on it
