pull injectors
pull injectors
Postby Redneckintraining » Sun Apr 19, 2009 4:42 pm
I need to pull the injectors on my 89 W250 to get them cleaned and pop tested.the lines dont look hard to pull but how do I undo the big nut that holds the injectors in place?
thanks in advance.
Redneckintraining
Postby PToombs » Sun Apr 19, 2009 4:45 pm
Pull the lines and use a deep well socket. Most of the time they'll pop right loose. If it feels funny, switch to a wrench and see if the whole injector is turning. If so, you'll have to try to hold it with a wrench on the flats of the injector. Spray lots of Blaster or some such will help too.
Postby Oddfire » Sun Apr 19, 2009 7:08 pm
-24mm on the injector hold down nut
-a nice crisp, good quality crescent on the injector body to hold it from rotating
Cummins makes a slide hammer to pull them to the toon of about $120. Snap-on makes an adapter that threadt on the injector body that attaches to there small slide hammer, but the adapter is around $38 and the slide hammer is around $90.
I had a stuck injector when I did my swap and had to build a slide hammer using a top nut off of a spare set of injector lines, some small rod and a piece of a 2" hyd. cyl. shaft. Cummins never got the #6 stick seated on the crush washer in my motor, so the body was fully incased in carbon. And to boot it was the #6 hole, so I had to pull the hood to get a streight shot at it.
Also, once you pull the retaining nut, lightly smach the injector with a brass drift down where it enters the head. This will help bust loose any carbon buildup there may be. ;)
Oddfire
Postby cougar » Mon Apr 20, 2009 7:54 am
Does anyone know what the thread size is on the injector body?
I have a slide hammer, all I need is an adapter.
01 2500 "the work truck".
cougar
Postby IRoss » Mon Apr 20, 2009 8:00 am
M12 metric fine, with a 1.5 pitch....kinda hard to find ;)
91.5IC 4x4 5spd extra springs
valet, 190s, ,18cm, 4"ëxh.
H4 conversion w/relays
rwal mia w/prop. valve
IRoss
Postby Oddfire » Mon Apr 20, 2009 9:55 am
The snap-on adapter is a good tool to have because it has a swivel in the middle and 8mm threads on the top. So with a litthe work it can be adapted to anything. 8) If not, check a few local diesel shops to see if they have a used injector line nut you can have. You will be surprised. :lol:
p.s. the cummins slide hammer is quite small because it doesn't take much. Be carfull not to damage the injector with a larger tool. ;-)
Oddfire
Postby fasttalker83 » Mon Apr 20, 2009 3:23 pm
I have a slide hammer that I use and what we have done is take an old injector line and take the nut off the end and weld it to a nut that fits your slide hammer I have made this both for the first gen and for the sec. gen injectors hasnt failed yet the slide hammer can be bought for 45.00 it is a OTC tool built for Ford injectors
fasttalker83
Postby PToombs » Mon Apr 20, 2009 4:55 pm
Some guys use metric lug nuts and weld it to the correct size to adapt to the slide hammer. Cheaper than any of those adapters! ;)
Postby Richie O » Mon Apr 20, 2009 5:01 pm
Some people get lucky and they just come right out. :D
Postby 921stgen » Mon Apr 20, 2009 6:55 pm
This is what I did. I used a lug nut and welded it to I think 1/2" allthread and couldn't fit 3/4" pipe over the injector so I used 1" pipe and 2 washers and welded a nut on top with a nut in between just like the pics. In 15 min including making the tool the injectors were out, very simple. http://www.dieseltruckresource.com/dev/ ... p?t=124728
Here are some instuctions for reference if haven't pulled them yet. http://dodgeram.org/tech/dsl/injector_inst.htm
921stgen
Postby pulltilbroke » Wed Apr 22, 2009 8:20 pm
I used some 5/8 all thread some 1 1/2 pipe and a lug nut, cut the allthread to about 8" long, cut the pipe to 6 or so inches welded a washer to the top of the pipe and whala you have a 5 dollar injector puller/slide hammer
Postby cumminz90 » Sun May 03, 2009 6:20 pm
my injectors came with a nut that goes on the end i took a 6in long metric bolt that fit it it an cut sum round stock metal to make my on custom slide hammer out of stuff laying around in the shop it popped the carboned ones rite out :D
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Postby Redneckintraining » Tue May 05, 2009 10:20 am
Went and had the injectors pulled and tested.
they were all carboned up and were "pissy" that and they all poped about 600 psi less than what they where supposed to. new injectors are 365 for the set...expensive right now, but actually having something resembling fuel economy and power will be nice.
Redneckintraining
Postby dpuckett » Tue May 05, 2009 10:46 am
$365 aint bad for the set, and you will have plenty of growing room with the nonIC stockers. Get the injectors back to where they should be, and you will be amazed at the difference.
Daniel
