Turbo's
Turbo's
Postby Falcon » Wed Feb 28, 2007 3:08 pm
I thought I was getting to know this stuff but I don't. A stock HX35 has what size compresser wheel? I can get a stock turbo from a 98. Can anyone tell me what size the compressor wheel is? It also has a 12 cm WG housing on it. Right now I can't keep my turbo from barking when I get out of the go peddel fast.Should I get a larger compresser housing? If I do what would you reccomend? Thank you for your time in this matter.
Greg
Greg
Graham, Washington
"FIRST REAL TRUCK ENGINE...
LAST REAL TRUCK!!!
93 ex cab 4x4, Hybred 35/40,4" exaust all the way,pump turned alittle,DDP Stage III's, 366 spring,DDP fuel pin,AFE first gen air intake,pyro and boost gauges
Falcon
Re: Turbo's
Postby gman07 » Wed Feb 28, 2007 3:23 pm
Falcon wrote:I thought I was getting to know this stuff but I don't. A stock HX35 has what size compresser wheel? I can get a stock turbo from a 98. Can anyone tell me what size the compressor wheel is? It also has a 12 cm WG housing on it. Right now I can't keep my turbo from barking when I get out of the go peddel fast.Should I get a larger compresser housing? If I do what would you reccomend? Thank you for your time in this matter.
Greg
The HX35 from the 98 should have a 56mm compressor wheel (inducer). If you still have the stock H1C compressor side on your truck, the HX35 should eliminate the compressor surge.
It isn't going bigger on the compressor side that eliminates surge. The HX35 and WH1C have a Map Width Enhancement slot cut in the compressor side that reduces surge, whereas our stock H1C does not.
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby Greenleaf » Thu Mar 01, 2007 3:46 am
Right. The MWE slot helps. You can let up slower on the go pedle too. You can install a larger turbine housing which also will help.
You can still bark the newer turbo. I have an old H1 that I cut a slot into and it helped. Takes a little more effort to bark it now. With a little larger turbine housing, the air isn't pinched off so much, thus the compressor is turning a little slower when you pick your foot up.
Greenleaf
tech specialist/mod
Postby Falcon » Thu Mar 01, 2007 10:42 am
Ok I can get a 98 HX-35/ 12 cm wg in good condition for $250.00 or I can get a HX-35/16cm For the same price. I already have a 12 cm on my H1C now should I go with the 35/16 which I know nothing about or the 35/12 that I know is a good one?
:roll: Greg
Greg
Graham, Washington
LAST REAL TRUCK!!!
Falcon
Postby dpuckett » Thu Mar 01, 2007 11:02 am
There really isnt much to checking out a turbo. A long as it spins freely, and no blades hit the housing, consider it good. Personally, I'd go for the 16, especially if you are barking with the 12 now.
Daniel
Postby Falcon » Fri Mar 02, 2007 11:43 am
Turbo being shipped.
Greg
Graham, Washington
LAST REAL TRUCK!!!
Falcon
Postby rlyons » Fri Mar 02, 2007 6:17 pm
Get yourself a HTT Stage III and the bark will be gone. Much better turbo now, I get lower EGTs and more boost and the scream is great.
92 D250 Club Cab 4X2, 5 speed, ASA Modifieds Intake, Jannetty Racing Team Exaust System, Tweaked Pump, 3200 RPM Governor Spring, HTT Stage III Turbo w/16cm2 , Pyro/Boost/Tach Guages, Power Wagon Injectors, KDP Tabbed, Borgeson Steering Shaft.
rlyons
Postby gman07 » Fri Mar 02, 2007 8:36 pm
I think most, if not all, of the bark should be gone by switching to the HX35/16cm. If not, just let out of the pedal slower :P
gman07
